Author Topic: FLUKE TiS10 thermal camera RGB LCD panel replacement - advice needed please  (Read 1796 times)
Offline FraserTopic starter
I have started a thread in the 'Beginners' area regarding the replacement of the LCD panel in a FLUKE TiS10 thermal camera but thought it wise to highlight it here as well in case it is missed there. I am looking at fitting a generic RGB TFT LCD panel in the camera as the original is completely broken. The original panel uses only 22 pins to connect to the PCB and the Winstar has 54 pins so some adaption will be required !
https://www.eevblog.com/forum/beginners/replacing-an-unknown-rgb-lcd-panel-with-a-generic-type-advice-needed-please/
Fraser
