Author Topic: Fluke87III motherboard does not turn on.  (Read 1093 times)
Offline ramijoseferTopic starter
« on: December 19, 2018, 09:58:56 pm »
Good afternoon.
  I bought a new Fluke 87 III Multimeter Plate, without checking, and when I try it it does not turn on the multimeter.
I appreciate any guidance from similar experience, AND / or the motherboard scheme of said multimeter.
Greetings.
Offline Val Babakaev
Offline retiredcaps
Re: Fluke87III motherboard does not turn on.
« Reply #2 on: December 20, 2018, 06:19:17 am »
Let me ask the obvious question ... have you tried a brand new fresh 9V battery?
« Reply #3 on: December 20, 2018, 08:34:28 pm »
If I tried it with a new 9V battery.
Offline coromonadalix
« Reply #4 on: December 20, 2018, 09:39:19 pm »
There was a case of power on or off problem, i think it was the mosfets switching the battery on off
Check the attached image from the service manual :        83_85_87smeng0500.pdf]
You may have an similar circuit ??
Offline mzacharias
« Reply #5 on: December 20, 2018, 10:02:43 pm »
Don't rule out an issue with the battery connector. They often develop problems .
If you have not already - check the battery voltage at the circuit board and not at the battery itself.
