Author Topic: Fluorescent Lamp Inverter  (Read 1752 times)
Offline JDWTopic starter
  • Country: jp
« on: August 21, 2019, 09:43:41 am »
The following URL hosts some photos of a Fluorescent lamp I've been using for about 13 years.  It's been working fine until recently.  It now won't power on.  I recently changed the tube so I know that is good.  I confirmed the push switch is good.  The fuse on the inverter circuit board checked out good.  Yet it won't power on.  I know nothing about how these inverters work, so I'm not sure how best to test it further, hence my post here.
https://www.icloud.com/sharedalbum/#B0w52plgjNZIfl
I thought the small electrolytic capacitors (C5 & C16) might be leaking, so I replaced them but the lamp still won't power on.  And I know the power cord is good because I can measure the correct wall voltage coming through it to the circuit board.
Any testing tips or suggestions you could give me would be appreciated.
Thank you.
Offline goaty
Re: Fluorescent Lamp Inverter
« Reply #1 on: August 21, 2019, 09:48:24 am »
If you have a multimeter you could check the diodes and transistor for shorts and alike. I had one repaired where the power transistor (like your 2SC4546 NPN) was shorted.
  • Country: jp
« Reply #2 on: August 22, 2019, 09:55:41 am »
Thanks.
Diodes D1, D2, D3, D4 and D5 all show their forward voltage just fine with my diode checker, tested in-circuit.  I desoldered the 2SC4546 (NPN BJT) and put it on a breadboard and wired it up to switch GND to a test LED and it worked fine.
Any further thoughts?
  • Country: jp
« Reply #3 on: August 28, 2019, 06:21:54 am »
I guess I've stumped the experts here!   :)
Perhaps some electronics aren't meant to be fixed.
Thanks.
Offline fzabkar
« Reply #4 on: August 28, 2019, 06:41:02 am »
I would check the capacitance of the film caps. I also make it a practice to reflow the solder joints at all coils and transformers.
The following users thanked this post: JDW
  • Country: jp
« Reply #5 on: August 28, 2019, 09:20:17 am »
Thank you for the advice.
I removed all 6 film caps and measured the correct capacitance on all of them, as per their markings.  Not sure what ESR should be, but measuring with my DE-5000 at 100kHz, ESR on most of them were under 1-ohm, although C15 was about 2.5-ohms at that frequency.  Not sure if that is high or normal.
I then reflowed the solder joints at all coils and transformers and then tested.  Still a NO-GO.  My lamp won't light.
Any further ideas would be appreciated.
Offline soldar
« Reply #6 on: August 28, 2019, 09:57:45 pm »
Ifr you really want to spend time on this project I would start by reverse engineering the schematic.
But IMHO, if you want to be practical, I would go for an LED replacement.
The following users thanked this post: NiHaoMike
Offline james_s
« Reply #7 on: August 28, 2019, 11:14:02 pm »
Those are usually based on a Royer oscillator. Look for dipped film capacitors, especially if there is one across the fluorescent tube to allow current to flow to heat the cathodes before the tube strikes. I remember years ago I repaired quite a few of those curly CFL bulbs just because I could and often I'd find one of those film capacitors had shorted.
Offline QQE06-40
« Reply #8 on: August 29, 2019, 08:45:52 am »
Just a thought, because i had this happen several times before with SMPS's: check the higher ohmic resistores (>100k). They sometimes go o.c. with no obvious signs and for no obvious reasons. I see some of them on your pictures (R2/R22/R3/R4 e.g.). Have You checked R5? Seems to be a low ohmic fuse-resistor from the emitter of the switching transistor to ground.
Greeting,
Wolf
Offline Kartman
« Reply #9 on: August 29, 2019, 09:38:11 am »
I’d second checking the resistors. The smaller resistors suffer from electromigration at higher voltages and go open circuit. I spied a couple of 330k resistors near the transistor - i’d suspect them.
  • Country: jp
« Reply #10 on: September 02, 2019, 09:40:12 am »
Gentlemen, thank you for your suggestions.
R5 is marked "1R0J 1W" and measures 1.3ohms in-circuit.  It is light in color and easy to see there are no visible burn marks.  So this part would appear fine.
R24 measures 98.3k in-circuit.  Bands indicate it is a 100k.  So this too is OK.
R22 measures 231k in-circuit.  Bands indicate it is a 240k.  OK.
R2 measures 332k in-circuit.  Bands indicate it is a 330k.  OK.
R3 measures 325k in-circuit.  Bands indicate it is a 330k.  OK.
R4 measures 322k in-circuit.  Bands indicate it is a 330k.  OK.
R7 measures 33.5 in-circuit.  Bands indicate it is a 33ohms.  OK.
That seems to be all the resistors.  No problem here.
The 3 blue color caps are not "dipped film" that I can see insofar as they feel as hard as a rock and I must assume them to be ceramics.  I didn't test these yet but there is not visible cracking on any of them.
Hmmm...
Offline james_s
« Reply #11 on: September 02, 2019, 03:48:00 pm »
Film caps are hard as a rock too, and when any of these fail you can't tell just by looking at them.
  • Country: jp
« Reply #12 on: September 03, 2019, 09:23:59 am »
I desoldered all the blue caps and tested outside the circuit:
C8: Marked "104U" and measured 102nF, ESR=7.8-ohm @120Hz
C9: Marked "474" and measured 473nF, ESR=2.9-ohm @120Hz
C25: Marked "184" and measured 183nF, ESR=8-ohm @120Hz
No problem here.
Offline xmetal
« Reply #13 on: September 03, 2019, 10:15:21 am »
I vaguely remember having a similar problem with a circuit like that some years ago. It turned out to be the input voltage to the device was too low.
  • Country: jp
« Reply #14 on: September 03, 2019, 10:22:17 am »
If by "device" you mean the entire PCB I've been talking about, let it be known that the voltage is a wall socket.  It's designed for Japan to run on 100VAC at either 50Hz or 60Hz (since Japan uses both frequencies, depending on area).
Offline xmetal
« Reply #15 on: September 03, 2019, 11:36:06 am »
I can't remember what the source voltage was on the device I was working on but it was lower than it should have been and was stopping the fluorescent from working. It created the same symptoms as yours so I thought it was worth pointing out.
