Finally had time to identify most parts on the board, starting from the 3 wire 240v inlet, J1 Jumper, L1 JHD19006 60-120mH, R1 Glass fuse JF3, C4CE102M 1nf 240v,C5 MPX/MPK x2 SR-CAP .22uf 280v,L2 BXRJJ16002 4.1mH, D3-D6 IN4007, C6 SR-CAP .047uf 250v, C7 & C8 473J 47nf 630v, D9-D12 FR107,D7 & D8 IN4007, C1 & C2 22uf 350v, R3 51.3Ω .5%, D13 FR107, D1 DB3 C531 DIAC, Q3 X0619 Gate SCR, D2 DB3 C531 DIAC, Q4 S8050 NPN Tran, J2 Jumper, Q2 MJE 13007 Switch Mode NPN Bipolar Trans, R11 12Ω 0.5%, R13 1.8MΩ ?, D16 FR107,C12 10uf 50v, J3 Jumper, D17 FR107, L7 ?, R10 12Ω 0.5%, R12 ?, D18 & D19 FR107, C15 & C16 8.2nf 630v, Q1 MJE 13007, L3 & L4 LC25094 2.65mH, C13 & C14 15nf 1250v, D21 Blank, K2 6 wire outlet, D20 Blank,
Back Side
R16 - R21 1203, D14 ?, C10 ?, R22 & R23 5602, R14 & R15 224, R24 334,R25 1001, C11 ?, D15 ?, R26 4701, R28 0, R27 4701, C17 ?, R9 510, R5 - R8 224, C9 ?,
D14 & D15 are small SMD Zener Diodes as per picture, appear to be Black /Silver & SMD Caps I have no idea of the values. Appreciate any help on these.
