Hi everyone,
I have a Rohde & Schwartz HMP2020 PSU that works just fine. It's my go-to bench supply that I always use, never failed me.
I've opened it for cleaning and out of curiosity. In fact, I can post some more photos if you guys are interested.
Some of the soldering are a little bit ugly (see photos), and I think I can reflow them to make them more tidy.
Actually, I've bought that unit from that forum, from a guy in England (toploser if I remember), with a good discount.
I think it had some rework done on it, mainly replacing the power elements, hence the discount, otherwise everything else is from factory.
It's working perfectly, at a very good price, so I'm very happy, and it's just "cosmetic" rework.
When done reflowing, what would guys recommend as flux remover?
Currently, I'm using KF branded flux remover (
https://fr.farnell.com/kf/1019/nettoyant-flux-de-soudure/dp/3916613), that I actually bought from Conrad and not Farnell.
It does work, the flux is dissolved but when the cleaning fluid dries/evaporate there is some very thin "spread" residue.
So I would like to try something else this time. I'm considering the following options:
* Mg chemicals 4140A
* Electrolube FLU400DB
I've already bought some isopropyl alcohol made by MG chemicals and I've very happy. Hence I'll be glad to try their other products.
The Electrolube brand just seems as much reputable, if not more than KF, and is actually a bit cheaper (
https://fr.farnell.com/electrolube/flu400db/aerosol-fluxclene-400ml/dp/725663).
Also, there's the chemtronics brand that has a flux removal offfering.
Do you have any good recommendation? What's your favorite? What's your secret trick for a perfectly clean PCB ?
Best regards,
