What about some of the questions i posed?
Sorry didn't see your questions, I assumed it was the fuse, but the fuse in the unit is perfect. This is the issue in all channels the level are extremely low, I have disabled the transformer in mix control, I set first channel at flat and then checked all settings/presets. As for the rest of the channels 3-8 Same thing.
When I opened the unit all i did was dust it, Thats all.
https://youtu.be/IfnvA_Jya78I have made sure the pad is off, i mean the whole nine yards. I did a screen recording here is the link I posted on youtube,
At the time I did not have the UAD Twin available, when I did screen recording.
On the 56 the gain knob is at 6-7 and the level is so low and thats me being 10 inches away from mic, (Yes I have phantom power on, I've checked connections etc.) Now on the UAD, Digi 003 the level would be perfect at that gain level of 6-7, actually on the UAD Twin 5-6 is a great level.
Usually at that level and since I do not have a booth, I am able to hear background noise, such as TV, air conditioner or fan etc. Which of course when recording a vocal one wants to avoid all that stuff, I understand that.
Now if I turn gain knob of 56 to 8.5-10 I get a level that I should be receiving at 6-7.
Another thing, I do mic mods and the mic I'm using which is the mxl 910. I have upgraded, the capsule, and the circuit. Now when I connect the mic to the preamp of 56, I turn down volume when checking voltage with a multimeter. So the levels should read 55-60v, but it doesnt. Now there is nothing wrong with mic as I tested the mic on the UAD Twin I mentioned earlier. When I checked the voltage it read 63v, which then I had to tweak the mic untill the multimeter read 60v.
So maybe there is something wrong with the phantom power of the saffire 56.
If this helps and answers your question please let me know. It looks like I will have to ship interface to be fixed, but after reading a few forums and blogs I have learned that Focusrite or the third part who fixes their product have shipped back interfaces and the issue continues which they claim they couldn't find anything wrong with units.
I have been experiencing horrible costumer service from focusrite, I am starting to regret ever buying one of their products.
Is there away I can test the voltage of phantom power with a multimetter, to see if that is the issue?
in a different forum one individual stated this
"If it was a phantom power problem you would have normal levels with a dynamic mic (you should test it) if it's the case, check the caps in the AC input area.
I doubt we experience the same problem. On my unit it would record fine for a minute or 2 and then drop levels. Then I i put the gain to maximum and back where it was, levels would be normal again."
Where would I find the caps hat he is speaking of ?
do you have an image of what he is speaking of ?
