Unfortunately i had to permanently position Alcatel y900 4G hotpot on the charger, however, after a month the battery bloated and i’m afraid to leave it like that any more.
However, i don’t need the battery at the location at all but replacing the battery with just a power cable was not possible. The device doesn’t even turn on.
The battery is TLi036A1 with 4 pins.
pin 1. Vcc +
pin 2. (not marked) BSI or BTEMP
pin 3. GND
pin 4. (not marked) BSI or BTEMP
I remember that there were some “hacks” to emulate nokia batteries, which made it possible to use direct power at the phone battery pins.
So i tried that, i measured resistances:
pin2 - GND => ~8k
pin4 - GND => ~21k
(btw the pin2 - pin4 resistance was => ~29k)
Than i hooked the appropriate resistor, replacing the resistance of 8k and also tried adding 21k at the appropriate pins but it got the device to turn on, even expose the wifi, indicate 3G/4G connection and than RESTART. That way, the device was just in a loop, restarting.
Everything was powered with appropriate 3.8V as marked on the battery.
So, i believe this is pretty common issue for mobile repair shop, i was wondering if anyone have any suggestion how to trick the device (as it is essentially the mobile phone without physical interface) to turn on and stay like that.
Anyone have any suggestion/idea what to try? How to make this hotspot to run of the direct power?
thnx
