Author Topic: Samsung LCD T240 lines on display  (Read 1131 times)
Offline sairfan1Topic starter
« on: October 19, 2020, 09:53:04 pm »
I bought this used LCD i did not know it already has problem, when i turn it on mostly it starts with Image A, and then slowing changes to Image B, C, I opened the LCD and checked connections as in Image Inside.jpg both connection type A and B looks good,
When i plugged in HDMI it start giving me perfectly good image but after 15 minutes it went like this again, after trying it happened 2/3 times again that i got perfectly good image and then after 10/15 minutes it got lines back
Can someone help what could be the issue.
Offline Rasz
    • My random blog.
Re: Samsung LCD T240 lines on display
« Reply #1 on: October 20, 2020, 02:40:06 am »
poke ribbons with a stick once lines start showing up, if screen doesnt change at all when poking its inside the glass and unfixable
The following users thanked this post: sairfan1
« Reply #2 on: October 20, 2020, 02:56:51 am »
Thanks for reply, which ribbon cable, please refer to image inside.jpg is it marked A or B in the picture.
Offline Rasz
    • My random blog.
« Reply #3 on: October 20, 2020, 08:51:24 am »
all of them, gently
« Reply #4 on: October 20, 2020, 08:01:18 pm »
Please refer to image inside.jpg if connector type B having issue how can i fix it, do i need to put some hot air? if yes what would be the suitable temperature? i added new pictures, some time some part of screen is enabled and refreshed, but some time its all good.
Offline Rasz
    • My random blog.
« Reply #5 on: October 21, 2020, 12:53:37 pm »
does playing with ribbons do anything in the first place?
« Reply #6 on: October 21, 2020, 10:45:50 pm »
I did not get chance yet, but i was thinking how can i fix it if i found this issue, i have very limited space on my desk its hard for me to keep it laying down open
« Reply #7 on: October 26, 2020, 02:46:59 am »
I checked it, when i press ribbon (labeled B) in picture, image becomes clear for a while then i have to press it again, how can i fix it,
Can i do hot air fix? If yes what temperature is suitable
If hot air is not solution then how else i can fix it.
Thanks
Offline Rasz
    • My random blog.
« Reply #8 on: October 26, 2020, 09:29:09 am »
much older, less dense and easier to repair ribbon:
but I wouldnt go near modern LCD glass with hotair, in factory and professional repair settings its done with a hotbar machine like here
First locate exact spot where touching fixes the picture, then try touching it up with temperature controlled soldering iron, start with 250 Celcius like the setup on the tab bonding machine (profile was set at 245C 16 seconds)
« Reply #9 on: October 27, 2020, 05:38:35 pm »
wow, i was able to fix it, thanks a lot
