Author Topic: For.A FA-130P time base corector repair.  (Read 1422 times)
Offline JareTopic starter
« on: May 31, 2017, 08:09:26 pm »
Hi.
I have a For.A FA-130P time base corector that is broken.
It works when you turn it on when it's cold,
but after ten minutes it's got a little hot, and the image starts shaking up and down.
I figured out a bit by blowing on various ic's with air when it was hot,
and if i cool down an ic as it says "Sony 6090 CXA1054" on,
the picture will be fine again.
Could it be that the ic is broken?
And where can i find a new one i google it but found no one who sold the "Sony 6090 CXA1054".
Is there any other model that could work instead and what is it for?
Thanks.
Offline coromonadalix
Re: For.A FA-130P time base corector repair.
« Reply #1 on: May 31, 2017, 08:22:49 pm »
Search for Sony CXA1054 ...  unable to find a pdf sheet,  many websites pretends but give nothing.
Check for bad solders, bad contacts near that chip, on the chip, or nearby capacitors ???
« Last Edit: May 31, 2017, 08:27:02 pm by coromonadalix »
« Reply #2 on: May 31, 2017, 08:29:09 pm »
