Hey all.
I have an older cordless home phone that has a battery that will no longer recharge. My original battery is marked 2.4v 550 mAh Ni-MH. The new battery is marked Ni-MH 2.4v 300 mHa. the physical size is identical as is the pigtail connector (which makes polarity correct).
so basic question.....
I know that because the voltage, polarity and type are the same, it should power the phone handset. Since this is being used for a home phone, what will I notice if I drop from 550 mHa battery to a 300 mHa? is there any reason not to use these replacements?
phone handset is a SL82318 AT&T and replacements are marked Radio Shack 2302357 and the back does say Fits "many AT&T CL, EL, SL AND TL series phones"
I am just assuming I will get less talk time per charge but since these are generally returned to the charging cradles after the call ends (as opposed to staying on the coffee table), I don't think there will be a problem, right???
thanks
