Author Topic: FPC connector replacement identification and copper trace repair.  (Read 721 times)
Offline kaburaginootomeTopic starter
  • Country: id
Good day, gentlemen.
I have destroyed two of my FPC connectors because of pull force when opening the interior of a smartphone due to the incomplete weakening of the glue. I would like help to identify which connectors are those. (relevant images are prefixed with connector and fpc)
Also I need to repair a copper pad, I have thought of this and someone mentioned there's a copper tape you can cut and stick on the PCB, however, on the copper trace, there is a single SMD resistor that is dislodged from the trace as well. How should I progress with the repair?
Lastly, do they sell SPST momentarily switch that fits into holes supposed for a LED? PCB shots in kbpcb file.
Thank you.
Online coromonadalix
Re: FPC connector replacement identification and copper trace repair.
« Reply #1 on: May 07, 2019, 10:26:16 am »
First tell the model and brand
secoundo   you may need to buy a defective board to have thoses connectors
tercio          i dont know your knowledge or capacity to change theses connectors, they seems to be a pain to work with
Mybe you could find some   smartphone repair shop to do the job ?
