Author Topic: FPS 2000 random volume change  (Read 1597 times)
Offline i_like_sparksTopic starter
« on: September 21, 2019, 11:28:28 am »
Hello,
I have one of these oldies but goodies:
https://assets.hardwarezone.com/2009/reviews/others/fps2000/fps-2000.htm
Unfortunately it has started to randomly change volume every few minutes. It usually starts after a 1-2 hourse of use. Any idea what might be the cause? It's rather hard to debug due to the randomness.
Offline benj38
Re: FPS 2000 random volume change
« Reply #1 on: September 21, 2019, 11:37:35 am »
Bad connections or a bad speakers' relay (if the unit has one) are the first things that come to mind.
Online wraper
  • Country: lv
« Reply #2 on: September 21, 2019, 11:41:21 am »
Changes volume setting or just loudness with volume setting remaining the same?
« Reply #3 on: September 21, 2019, 11:49:21 am »
Just the volume setting. It does have an external volume/on-off knob, so I suspect it might be the potentiometer, but didn't have much success in cleaning it yet. Also I'm still puzzled where the randomness comes from. It's not crackling or so, it just changes randomly every few minutes.
Online wraper
  • Country: lv
« Reply #4 on: September 21, 2019, 01:10:15 pm »
Isn't it an encoder (can rotate indefinitely, no end stops)? Can it be disconnected?
Offline thehesiod
« Reply #5 on: May 23, 2020, 11:51:48 pm »
I have this exact same problem.  I just tried soaking the volume potentiometer in pure alcohol while messing with it, not sure it's going to solve the issue.  I have another issue as well.  If I have both analog inputs plugged into the back of the bass, but only one plugged into my laptop, swiping the L/R fader from middle to enabled side drastically changes the volume.  Anyone else have this issue?
Offline thehesiod
« Reply #6 on: May 24, 2020, 12:16:33 am »
verified it did not fix the random volume issue.  I'm guessing now it's a capacitor problem, I'll have to go through them all :(
Offline thehesiod
« Reply #7 on: June 01, 2020, 08:32:25 am »
ok I fixed the random volume issue (I think).  Wrote a blog entry about it here: http://hesiod.blogspot.com/2020/06/fixing-random-volume-on-cambridge.html
« Reply #8 on: February 21, 2021, 03:22:46 pm »
It's been some time but I wanted to be sure that the issue is fixed. I swapped the volume potentiometer with an identical newly bought one. This requires opening the little black controller, but isn't too hard. The issue has been fixed now for several months.
