Mine is still sitting on the bench waiting for me to continue looking at it - I've been helping a friend do some painting and that has sucked up all my free time. Hopefully later this week I will have time to dig into the schematics and try figure out how the blanking works.
This issue with yours still seems to me to be some sort of bad connection since it seems to work and then not work depending on its mood and the moon phase. That's a problem to try to trace.
-Pat
Yea i have definitely felt
, might help if i was smart enough to understand the schematics but then again it might help if the schematics were on paper so i could actually work with them.
The two screws on the display board that hold it in are missing so i take that to mean someone has tried to fix it before, which would ironically mean this problem is why it was so cheap
AND fully functional except from the display
Short excerpt from my head.
"So it could be as simple as say, a single bad solder joint?
Simple fix but it could take hours to find especially if it doesn't look obvious.
Well are the card's loose?
No the card's are not loose, i checked each one.
Got any ideas?
No do you?
Let's try wiggling a card again.
OK."
Yes, i talk to myself. Don't all mad scientists?
