Did you check the polarity? It's a silly but easy mistake!Anyways your board is now definitely fried, maybe they were already cooked by the LNK304 failure.Being a buck design, if the switching transistor shorts out it'll feed ~150V to the output, or ~320V in 220V countries!
Not sure you should double-check if the solder joints are OK. The one in the attached picture looks not good. Also the solder joints between the diodes should be checked.
Domestic fridge compressors are using inverters now? The look of that board with its obvious signs of heat damage and cheap electrolytic capacitors does not give me high confidence in long lifespan.
