Fridge has issues. Control unit at the back and bottom, housed inside a plastic box. Cables from said box into the bowels of the fridge through two small holes that have been sealed with some sort of resin/glue/rubber grommet. No extra length on cables to allow the plastic box that houses the control unit to be pulled out and examined. It appears when the fridge was being assembled they pushed any extra length of cable inside the fridge (the space between the back and the inside) and then sealed the holes with this rubberized glue thingy.
I cannot therefore pull the control unit out and pulling on the cables does not help, they must be glued inside the hidden fridge space very tight. The back of the fridge has been welded shut, no screws to take back covers off. Similar problem with cables inside the fridge and freezer compartments, they emerge from small holes into the back of the fridge, but there is no play, no extra length at all. It seems they fitted the fans, thermostats, console with lights etc, pushed extra cables into the holes, and then used some sort of glue/expanding foam to seal those holes.
Any idea how to pull out the control unit out to carry out a repair? As a desperation (as I will throw the fridge otherwise) I can use wire cutters to cut the two cables as close as I can to the control unit, and then somehow reconnect them with extra lengths.
