Author Topic: fridge thermostat replacement  (Read 1060 times)
Offline m3vuvTopic starter
« on: October 11, 2020, 02:04:25 pm »
Hi all,ive a logik fridge model LUL50s13 feidge with a buggered thermostat,the old one has 3 terminals,the new one has just two,can it be made to work with the 2 wire instead of 3?,cheers in advance.
Re: fridge thermostat replacement
« Reply #1 on: October 11, 2020, 02:12:27 pm »
heres a pic of the original stat wireing diagram.
Offline andy3055
« Reply #2 on: October 12, 2020, 02:19:59 am »
one of them looks like a ground of the thermostat case.
Offline james_s
« Reply #3 on: October 12, 2020, 04:25:10 am »
Yes you can ignore than third wire, it's just the ground. There are only two wires going to the thermostat in that diagram that carry current.
Offline perieanuo
« Reply #4 on: October 12, 2020, 01:22:42 pm »
hi,
be careful and 'ignore' the ground connector, identify this one with a multimeter, if you gonna plug the new thermostat between L and Earth you gonna trip the breaker
don't trust the colours
Online themadhippy
« Reply #5 on: October 12, 2020, 01:32:50 pm »
might be the original stat has 3 connections,plus earth, were 2 of the connections are commoned. power in goes to 1 of these terminals  and the second connection is the internal light via a switch
