Yes an interuption. I bridged the component but still no go. Didn't test out if the GPU as getting warm before that procedure due.
Do you guys know any particular places to measure on this PCB?
More information is that I think it got really hot before (or during) it died. Seems that some liquid (from the solder?) has flowed over the PCB at some places, like at the VRAM and around the PCIe slot.
Sorry for the card
It really is not good idea to short a fuse as fuse broke for a reason (there was some other problem that caused too high current flow)
Fuse blew in attempt to protect further damage and bridging it can lead to this damage.
Any case what is done is done.
I would think the most common faults will be GPU VRAM and if these are done card is done as it is not feasible or cost efficient to replace those components most of times.
Voltage regulators can also become faulty maybe someone can help further.
Best of luck !
