Author Topic: Fuji HS10, need to find a connector.  (Read 476 times)
Offline screwbreakerTopic starter
« on: July 26, 2020, 09:33:56 am »
Hi there.
I'm trying to fix a Fuji HS10. I need to replace the connector for the top unit with the on/off switch.
1033308-0
The connector must have the same specs of this one:
https://lcsc.com/product-detail/FFC-FPC-Connectors_JUSHUO-AFE03-S23FMA-1H_C262543.html
https://datasheet.lcsc.com/szlcsc/1811021329_JUSHUO-AFE03-S23FMA-1H_C262543.pdf
Except that the connections must be on the top. Because the flat flex have the contacts on the top side.
1033312-1
Many thanks in advance to everyone for the help.
