Author Topic: Fujitsu E754 EC bios update killed pc  (Read 1315 times)
Online pienariTopic starter
« on: August 13, 2023, 05:44:31 pm »
I have been looking for workking bios and ec file.
https://aijaa.com/Xe3fQ7
Board is CP620570 , CP642134-X3
https://aijaa.com/dBYLwb
I removed both eeprom chips and read data.
25Q32
25Q80
Bios file size is 4mb and ec is 1mb
Bios file was readable but ec was blank.
I have tryed all files found from net but no luck.
Have anyone backup files?
« Last Edit: August 13, 2023, 06:22:30 pm by pienari »
Offline fzabkar
Re: Fujitsu E754 EC bios update killed pc
« Reply #1 on: August 13, 2023, 06:32:25 pm »
Is this the update?
EC Firmware Update for LIFEBOOK E7x4 vPro:
https://support.ts.fujitsu.com/indexdownload.asp?Softwareguid=1f74b5ad-5303-45ae-b310-abff9b23cad2
If so, I was able to extract a file named 4C46D217.EC1 from the .exe by using 7Zip. This looks like it might be the EC image you are looking for. I don't know if there are any reserved, unique regions, but it would be worth a try.
« Reply #2 on: August 13, 2023, 08:26:11 pm »
Hi.
This is non vPro model.
Offline fzabkar
« Last Edit: August 13, 2023, 11:03:17 pm by fzabkar »
« Reply #4 on: August 14, 2023, 05:12:30 am »
Hi.
I really dont know, laptop was dead when i get it for free.
Thank you for the links, i havent found those from Fujitsu page.
I downloaded both your linked files and cheked that EC1 file.
It is a bit smaller file size vs. what i found from web.
I have to flash that to eeprom and test.
« Last Edit: August 14, 2023, 05:14:28 am by pienari »
Offline fzabkar
« Reply #5 on: August 14, 2023, 08:25:31 am »
I found this, but the EC file looks nothing like the update:
https://forum.laboneinside.com/viewtopic.php?t=358
The EC1 file appears to be an update for the East Chip microcontroller, whatever that is.
« Last Edit: August 14, 2023, 09:44:20 am by fzabkar »
« Reply #6 on: August 14, 2023, 09:58:23 am »
Yep.
That is different model with 8mb bios.
I have tested that and dead as rock.
EC update is something to do with battery charging controller.
I think bios files can fit from E735,E745 and E755 laptops.
« Last Edit: August 14, 2023, 10:06:31 am by pienari »
« Reply #7 on: August 14, 2023, 10:16:32 am »
Now i found this.
https://www.badcaps.net/forum/showthread.php?t=58246
E734 bios + ec
I have to check if that works
« Reply #8 on: September 01, 2023, 03:04:58 pm »
That bios+ec not helped.
I bought E754 motherboard from ebay and received it yesterday.
Installed it and computer boots now, but black screen.
External display picture is ok.
Fuse near to display connector is fine.
