I bought a rotary laser level that is faulty.
Original fault was that the laser would turn on immediately when the battery is connected and operate normally, but after pushing the power button the LCD would dim and the backlight would flicker, but never power off.
During my diagnosing I decided to power the laser level direct from my digital bench power supply to see what the current draw was at 6V.
Unfortunately I found out 6V was more than a component on the main PCB could handle (even though the laser level also runs off 4x 1.5V C cells in series??).
A SOT23/SOT753 5-leg component with the markings 9A9B let out the factory smoke.
I am having a hard time finding out exactly what it is and what it does, but I believe it may be a LM3671 DC converter (or equivalent). If it is, I suspect it's the fixed voltage type, but I'm not sure that it isn't variable.
The component burnt out between where the switching FET might be on a LM3671 (Pin 1 and 5).
What is the burnt component?
Answer:
SOT23-5, 4V LDO regulator. Possibly 'Belling' brand.For bonus points, what might cause the original fault of not powering off?
Answer:
The 'N2 and N3' regulators were leaking voltage through, even with no voltage to the enable pin.
Note:
The burnt component was in 'N3' position on PCB (lower left quarter of PCB). I took 'N2' from next to the beeper (upper right quarter) and put it in 'N3' to see what would happen.
N1, N2, and N3 are all the same part and have the same circuitry and components in immediate vicinity.
AFAIK the lasers run on 3-5V (connectors on lower left).
The line colours in the picture (except for red and black) have no significance other than to make them more visible.
I have contacted the laser level manufacturer about getting a replacement PCB (if I have no other option) but they haven't responded.
