Author Topic: Help finding a LCD screen for a Blood Pressure Monitor  (Read 2375 times)
Offline PonzaroTopic starter
« on: June 15, 2016, 11:17:42 pm »
Hi  :)
I have a blood pressure monitor (Avita BPM645 - http://www.avita.com.tw/BPM64en.html) that has the LCD broken and doesn't work. The problem is that I can't find the replacement LCD, because there aren't model or serial number on the screen that can help identifying the part  :( I attach two screenshot of the front and the rear of the screen
The only text is the letters and numbers that are on the rear. If aren't readable well here they are:
EDC5558C1 060208
060123-0198 BP64-2
I've tried to search those codes in Google but didn't find anything
If anyone can help in identifying this component and find where to buy online would be great, thank you  :D
Offline TheMG
Re: Help finding a LCD screen for a Blood Pressure Monitor
« Reply #1 on: June 16, 2016, 12:26:32 am »
That's a purpose-specific LCD, manufactured for that specific product, and not a standard LCD display.
Unfortunately, unless you can find another unit to salvage one from or obtain a replacement from the manufacturer, you're probably out of luck. :(
« Last Edit: June 16, 2016, 12:29:00 am by TheMG »
« Reply #2 on: June 16, 2016, 07:44:46 am »
Understood, thanks for the reply  ;)
Offline wagon
« Reply #3 on: June 16, 2016, 11:36:04 pm »
Have you tried the manufacturer of the machine?  I've had some success doing that in the past with other things.
Hiding from the missus, she doesn't understand.
« Reply #4 on: June 17, 2016, 07:14:52 am »
Sure, I tried but the answer was totally useless  :(
