Author Topic: GAP1093 phototransistor for OPM4 fiber meter needed.  (Read 664 times)
Offline Ordinaryman1971Topic starter
« on: October 31, 2023, 07:56:46 pm »
I'm looking for replacement for this photoelement on the fiber meter made by Noyes OPM4.
It's marked as GAP1093.
Re: GAP1093 phototransistor for OPM4 fiber meter needed.
« Reply #1 on: October 31, 2023, 07:59:24 pm »
Here are pictures of meter and the sensor
Offline Kleinstein
« Reply #2 on: October 31, 2023, 09:17:55 pm »
It is very likely not a photo transistor, but a photodiode.  Optical fibers often use some 1.55 µm and thus can not use si detectors anymore. With the longer wavelength materials phototransistors are not at all common - likely not available at all.
« Reply #3 on: November 01, 2023, 11:51:54 am »
I've done some google-fu and nothing came up, you are most likely right.
So... if they are not silicon based... what would be the material used for the detector part.
« Last Edit: November 01, 2023, 12:01:48 pm by Ordinaryman1971 »
Offline Kleinstein
« Reply #4 on: November 01, 2023, 02:27:05 pm »
My best guess on the detector material is InGaAs, as this is good to some 1.8 µm wavelength and still available as a standard type. Even mouser has a few in stock.
Another possibility may be using a thermopile to get a wavelength independent response, though at a much lower sensitivity and thus only a thing for relatively high power.
Offline Haenk
« Reply #5 on: November 01, 2023, 06:06:17 pm »
