Author Topic: Marconi 2955B CRT Issue - Can only see the extreme edges of the Geometry  (Read 701 times)
Offline ReprobyteTopic starter
Edit - Moved to Marconi boards as advised
« Last Edit: June 14, 2023, 01:09:24 pm by Reprobyte »
Offline George Edmonds
Hi
You need to be posting here.
https://groups.io/g/Marconi-Test-Instruments
The Marconi Instruments support group on groups.io
G Edmonds
The following users thanked this post: Reprobyte
Online wasedadoc
The vertical scan appears to be upside down.  Check vertical sweep generator, vertical output to deflections coils or plates depending on magnetic or electrostatic deflection.
Hi
G Edmonds
Thanks for the heads up George, I have moved the discussion over there.
