Author Topic: Gardena R70Li main board repair, what component is it?  (Read 1079 times)
Offline sailor83Topic starter
  • Country: no
« on: May 02, 2020, 05:14:22 pm »
I've been fault searching on a main board for a Gardena R70Li robot lawnmower.
One output, the left one is faulty, by changing motors, the oposite doesn't work.
I've found this to be faulty:
But what is it? the left to legs are shorted.
It looks like the writhing says:
F (logo) 1E34AC
FDD
8424H
It's probably a TO252 DPAK package, the centre circle says AB.
I've been trying to googling the component, but can't find it, any suggestions?
  • Country: no
Re: Gardena R70Li main board repair, what component is it?
« Reply #1 on: May 02, 2020, 05:19:51 pm »
You always figure it out after asking for help..
Probably this one: https://no.rs-online.com/web/p/mosfets/6710356/  ?
Online coromonadalix
« Reply #2 on: May 03, 2020, 03:38:20 am »
Never saw that type of case  :o
Offline pico61
« Reply #3 on: May 04, 2020, 10:20:45 pm »
Yes, most likely it's it. :-+
On the other hand, mosfets are used as drivers of DC motors.
If one end of the motor is connected to the component, then it's definitely a mosfet.
Offline sancho_sk
« Reply #4 on: May 29, 2021, 07:35:58 pm »
Not sure if this is still helpful, but in my R70li the part is AOD609.
Here is the datasheet.
https://www.tme.eu/Document/435d6c3893606163299f67de36ec8c28/AOD609-DTE.pdf
Unfortunately, on mine not only the output FET burned, but so did the BC817 that is driving it and also the 74HCT365 that provides the signals as a buffer from the CPU...
So, my fix will not be as easy...
