Wait I think I saved one shot so perhaps it may help everybody see what I was dealing with.
What's shown in the attached photo is the back of the subwoofer with the amplifier in a working position, you can see the inner part of the plastic box with conductive paint.
Perfect! Now I can be clever (😁) and say that it doesn't look like a paint, but like a metallization. You can see this suspiciously shiny "paint" in many places, especially very often in laptops and the like.
Now, the amp was initially mounted in a way upper position. And it was VERY tight. So my conclusion is that the solder side of the electronics that can be seen here were making contact in at least one point, making a short or something like that.
As a matter of fact, as soon as I removed the amp from the chassis (or simply shifted the installation in a lower position, as per photo) it started working again.
Okay, let's do a little analysis.
Here are photos of the insides of this module (with some of my notes):
As I can see, there is sufficient clearance between the switch-mode power supply board (SMPS) and the metallized case. The same cannot be said about the audio power amplifier board (PA) installed at right angle.
I guess the most likely reason lies somewhere here:
