Author Topic: General questions about LCD panel replacement  (Read 1616 times)
Offline ajrabassaTopic starter
« on: December 22, 2015, 11:43:14 pm »
When looking at potential repair projects, I'm coming across things with dead LCDs.
If I can't find the service manual and parts list, how difficult is it to replace/source an LCD panel? I'm asking in general, I understand there will be outliers in both directions. Are they generally driven the same way in standardized form factors, where I can find a very similar LCD and put it in? Or should I assume I need to find the exact same LCD for a given device?
Offline Stonent
Re: General questions about LCD panel replacement
« Reply #1 on: December 23, 2015, 12:03:33 am »
I've seen it go both ways.
For things like laptops, it's very easy as you can google the part number or go to a laptop LCD site and put in the model number.
Many laptops have a standard type of connector so you have to match connector, resolution, size, connector location and whether or not it uses CCFL or LED.
Resolution can be an issue because most laptops over 1366x768 have a different cable than ones that are 1366x768 or lower because it required both channels.
Other devices I've had a harder time with if they aren't common things like portable video games.  We had a timeclock at work that had a cracked screen and I googled every number on the LCD module and found absolutely nothing.  When I contacted the vendor, they would not give me a part number, just said for us to send it in for refurbishing.
Offline wraper
  • Country: lv
« Reply #2 on: December 23, 2015, 12:16:50 am »
Your question is completely pointless without saying what kind of device, and preferably models too. There is no general answer.
« Reply #3 on: December 23, 2015, 09:35:17 pm »
Thanks - this is pretty much what the consensus seems to be, it's either relatively easy to find, or it's next to impossible.
