Author Topic: How to open flex cable connector  (Read 520 times)
Offline lartsuTopic starter
« on: April 15, 2024, 04:23:38 pm »
Could you help me a bit..
I'm not sure how to open this type flax cable connector (Nikon Z7 lcd cable). How to open this type of connector?
Thanks in advance.
« Last Edit: April 15, 2024, 06:03:17 pm by lartsu »
Online jpanhalt
Re: How to open flex cable connetor
« Reply #1 on: April 15, 2024, 04:34:32 pm »
There's usually a lever on the side that lifts up and releases the FFC.  On this connecter, it looks like the white piece may be that part.
Re: How to open flex cable connector
« Reply #2 on: April 15, 2024, 06:06:16 pm »
It seems that there is no lever to lifting it up. I want be sure how to open this type of connecter.
Online jpanhalt
« Reply #3 on: April 15, 2024, 07:17:05 pm »
Here's a grossly similar one from Molex.  It is open, and apparently the black part just tilts up.  In all cases I have seen, a part over the cable swings up.  When you re-insert the cable, it snaps back down to hold the cable.  Do that carefully to be sure everything is aligned.  Some have a latch on the side, others, just a fingernail under the movable part opens it.  The Nikon D70s  I disassembled was the latter type.  The latch was brown rather than black.  It doesn't take much force.
Be sure us wear ESD protection.
« Reply #4 on: April 15, 2024, 08:02:55 pm »
It's not same style as in your picture which opens on cable side.  There are also these connecters but this connector in question is different. Most likely it opens on other side but I want to be sure.
Offline amyk
« Reply #5 on: April 16, 2024, 03:39:03 am »
The following users thanked this post: lartsu
