Hello people.
I have buying two GenRad 1687 (B) RCL Digibridge, but without active probe.
Schematic tell me, it contains a transformer.
It must transfer 1MHz signal without phase shifting. On my works is TC4-1T RF minatur transformer using for TTL-ECL Clock shifting
I have tried with him (in backwards) and 12 Ohm at secondary winding: a bit about 1V RMS, it is very good. A big luck, that it fit with 12
resistor very well (a bit much, 70mVrms to much). Obiviously , zero phase-shifting condition with TC4-1T is satisfied.
https://www.minicircuits.com/pdfs/TC4-1T+.pdf
active probe with manhattan style. After few trial & error with capacitor at input for impedance amplifier runs it with pausible value on display. Impedance amplifier is a MAX4477 , of course is it too slow (to much phase shifting)
I'll trying with video-buffer. Sziklai-pair is just a ordinary emitter-follower, typical early ciruit for using in fast signal acquisition.
But, my result with MAX4477 tells me: This is why is using transistor with fT of gigacycles.
Cable is high quality VGA cable, it was accessory of BARCO monitor.
