Author Topic: GHD 4.2B Working only in UPS  (Read 676 times)
Offline LuckyTopic starter
« on: March 03, 2023, 11:00:40 am »
Hi, I have this GHD hair straightener and makes a weird thing. If I plug it into the wall outlet, it doesn't make anything, but if I plug it into an UPS powered outlet, then it works perfectly.
Can anybody help me?
Offline Swake
Re: GHD 4.2B Working only in UPS
« Reply #1 on: March 09, 2023, 08:12:26 pm »
Sounds like the outlet has some issue or power limitation. I assume the plug makes good contact in the socket and the output voltage of the outlet is the same as the UPS.
Try the GDH in another known good outlet.
Try another device of 150W or more in the original outlet.
Eventually try inverting the plug, I mean turn it 180° in the socket if the model of the plug allows for this? In this way it inverts fase and neutral.
When it fits stop using the hammer
« Reply #2 on: March 16, 2023, 12:23:49 pm »
Outlet works Ok, it delivers 237-240V but UPS delivers 220 exact.
Offline m k
« Reply #3 on: March 19, 2023, 01:15:03 pm »
Over voltage it then seems to be, not necessary the actual on.
I assume you've swapped plug sides and it's double protected device and 2 prong plug.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-OR-X-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
