Author Topic: Gigabyte Brix Pro 4770R motherboard shorted!  (Read 3359 times)
Online gamalotTopic starter
  • Correct my English
    • Youtube
« on: December 20, 2018, 07:30:52 am »
This mini PC is powered by a common laptop style 20V/7A DC power adaptor. When I connect it to the mains, the power adaptor will enter the protection state and cut off it's output to PC.
I measured the input resistance of the PC's power in jack, which was determined to be shorted. I also measured all the MLCCs on the motherboard, between 20V rail and ground, all their resistance values are less than 100 milliohms.
Any suggestions? MLCCs, MOSFETs, or maybe DC-DC converters?  :-//
Offline Mechatrommer
  • Country: my
  • reassessing directives...
Re: Gigabyte Brix Pro 4770R motherboard shorted!
« Reply #1 on: December 20, 2018, 11:39:06 am »
heat gun? starting from input jack?
Online wraper
  • Country: lv
« Reply #2 on: December 20, 2018, 11:59:57 am »
Look for TVS diode connected between 20V rail and GND.
    • Youtube
« Reply #3 on: December 20, 2018, 01:16:22 pm »
It seems like the input jack is OK.
    • Youtube
« Reply #4 on: December 20, 2018, 01:17:15 pm »
I didn't find anything looks like TVS.  :-//
    • Youtube
« Reply #5 on: December 20, 2018, 01:18:18 pm »
Damn it! I can't even get a capacitor off the motherboard, it must be red glue !!!  :wtf:
Online wraper
  • Country: lv
« Reply #6 on: December 20, 2018, 01:25:31 pm »
Very unlikely. Not used motherboards. Post photos of the PCB.
TVS diode should look like this:
    • Youtube
« Reply #7 on: December 20, 2018, 01:35:59 pm »
I know TVSs look like diodes, actually I have even checked all TO23 components.
Pictures attached, sorry maybe they are not clear enough.  :)
Online wraper
  • Country: lv
« Reply #8 on: December 20, 2018, 01:42:42 pm »
Do you mean black capacitor nearby connector? If it's sitting on 20V rail, quite possible it has gone short.
    • Youtube
« Reply #9 on: December 20, 2018, 01:46:54 pm »
Do you mean black capacitor nearby connector? It's quite possible it has gone short.
No, I mean those size 0805 MLCC capacitors. Big black components are 330uf tantalum capacitors, maybe only rated at 2V, I guess.
  • Country: my
« Reply #10 on: December 20, 2018, 02:06:12 pm »
next? black ic and diode near it look interesting. the 2nd left diode? in the group of 4 also looks not so good.
    • Youtube
« Reply #11 on: December 20, 2018, 02:28:12 pm »
Those things look like diode are actually low voltage tantalum capacitors.
    • Youtube
« Reply #12 on: December 20, 2018, 03:19:19 pm »
Finally I decided to add 5A current to the motherboard, after a few seconds a DC-DC chip becomes very hot!  >:D
Offline Rasz
    • My random blog.
« Reply #13 on: December 20, 2018, 03:50:27 pm »
8 or more layer pcb, hotair + preheater or you risk deforming/ripping pads off
take off TPS51363 and measure again
I would also measure all the PL inductors to ground
« Last Edit: December 20, 2018, 03:53:13 pm by Rasz »
    • Youtube
« Reply #14 on: December 21, 2018, 05:50:58 am »
The trouble I am having now is that I don't have a preheater.  :-//
  • Country: my
« Reply #15 on: December 21, 2018, 06:16:38 am »
check downstream for the short. or disconnect load if possible. and also check the dc dc if its "pwm"ing.. tool needed... oscilloscope.. >:D thats the reason i bought seek thermal >:D
