Author Topic: Gigatronics 6062A inside picture wanted  (Read 1910 times)
Offline charlydTopic starter
« on: December 11, 2017, 07:30:04 pm »
hello today i got my new project in the Gigatronics 6062A  it startups, display lights-up with some values on the display so things looks good.. but when i open the unit my eye fell on the empty U26 chip and the dallas chip...
do i miss a chip here is my question.
maybe somebody with a Gigatronics 6062A can send a picture from this part from a working generator.
Offline SMB784
    • Tequity Surplus
Re: Gigatronics 6062A inside picture wanted
« Reply #1 on: December 11, 2017, 07:36:53 pm »
I would first test to see if the device is working.  Hook it up to an oscilloscope and program it to some frequency values less than the bandwidth of your oscilloscope.  If they are in line with what the generator says it is putting out, I wouldn't bother messing with anything inside.
Offline RobK_NL
« Reply #2 on: December 11, 2017, 08:37:18 pm »
1). Get the manual here: http://www.ko4bb.com/getsimple/index.php?id=manuals&dir=Fluke
2). Read section 4D-11
Tell us what problem you want to solve, not what solution you're having problems with
« Reply #3 on: December 11, 2017, 10:22:40 pm »
hi thanks for pointing me to the manual i only had the gigatronics, now both, you are right. i was just curious it caught my eye.
« Last Edit: December 12, 2017, 08:26:57 pm by charlyd »
Offline RobK_NL
« Reply #4 on: December 12, 2017, 09:59:21 am »
4D-11 explains what U26 is for and that should make it clear why it is not installed.
Gigatronics 6062A + dalles Chip replacment
« Reply #5 on: March 12, 2019, 09:24:36 pm »
Hello just a question about the dallasChip (location U23)
is it a good idea to replace this chip with a new DALLAS 1225AB.  because of aging?
Does anybody have ever replaced this chip inside a 6062A ?
