Author Topic: Glass Diode Identification 15PP?  (Read 904 times)
Offline kishbud
« on: January 20, 2022, 10:57:48 pm »
Power supply repair but this one diode I cannot identify or locate online, hopefully someone knows!
Offline abdulbadii
Re: Glass Diode Identification 15PP?
« Reply #1 on: January 21, 2022, 04:33:03 am »
likely ZD, zener diode
Offline kishbud
« Reply #2 on: January 23, 2022, 04:45:05 pm »
Yes, thank you but what does the making 15PP stand for so I can find a replacement?
Offline fzabkar
« Reply #3 on: January 23, 2022, 05:05:28 pm »
15V, 1W Zener?
A photo of the surrounding electronics may help.
Offline cybermaus
« Reply #4 on: January 23, 2022, 09:28:12 pm »
Out of interest, why is the diode suspect?
Or is this where you replace all diodes and electrolytes while working on a PSU, just in case? If that is the case, you could skip this one?
Offline Audiorepair
« Reply #5 on: January 23, 2022, 10:13:18 pm »
Zener diodes usually have significantly higher Forward Voltage that standard rectifier diodes.
So if this diode is still working, put your meter in diode mode and measure a few standard diodes you know to be rectifiers.
They usually read in the 500mV to 600 mV ballpark.
A Zener will often read in the 700mV ballpark, making them quite easy to spot.
I would agree with others here that it looks quite likely this is a Zener.
Edit:  You can nearly always measure these Forward Voltages in circuit, so you don't need to remove any of them to test.
Just get a handle on what a normal diode looks like and you will spot the Zener a mile away.
« Last Edit: January 23, 2022, 10:28:35 pm by Audiorepair »
The following users thanked this post: sean0118
Offline kishbud
« Reply #6 on: January 24, 2022, 10:03:49 am »
The power supply has a 3 position POT from 4.5-8v output for driving a medical light, after the initial repair, the 4.5v stage worked just fine but the 6v stage fried the 100ohm resistor in under 3 seconds (circled in red). So I have another guy working on it and he's repaired it so the resistor no longer lets the goast out but has come to the conclusion it might be the Zener to get fully operational and asked for my help identifying the diode to try a replacement but wants to know exactly what type and rating.
Offline mariush
« Reply #7 on: January 24, 2022, 10:19:27 am »
I'd check and make sure someone didn't accidentaly replace a diode with that 100 ohm resistor in the last two pictures.
There's 3 diodes to the right, and it's looking awfully close to a bridge rectifier pattern, maybe it's some auxiliary winding from the transformer getting rectified, then smoothed out by the capacitors to the right.
The 68 ohm chipped resistor looks like a minimum load resistor to me...
Offline cybermaus
« Reply #8 on: January 24, 2022, 10:41:24 am »
Well, it is a switched PSU, so there should be one bridge rectifier should be on the primary side, and those diode's do look to be on the primary side, but not really between the filter and the capacitor. Anyway, some trace following may easily show if they are in a bridge configuration.
Say, slight tangent: Those yellowish X2 capacitors. They are not the infamous period appropriate RIFA's are they?
« Last Edit: January 24, 2022, 10:44:21 am by cybermaus »
Offline kishbud
« Reply #9 on: January 24, 2022, 06:26:28 pm »
Good question mariush but no I was the first to work on this and those are my pics of when the 100ohm resistor let the goast out and I replaced it.
Offline kishbud
« Reply #10 on: January 24, 2022, 06:29:43 pm »
Cybermaus they certainly do look like those type of caps don't they.
Offline SoundTech-LG
« Reply #11 on: January 24, 2022, 08:18:37 pm »
The diode part# is likely 1S prefix not 15... (many vintage Japanese diodes)  however the letters PP seem very odd.
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313&_nkw=1s++diode&_sacat=0&LH_TitleDesc=0&_odkw=1s+germanium+diode&_osacat=0
Offline kishbud
« Reply #12 on: January 24, 2022, 08:19:22 pm »
Ever since I gave it to another guy to repair, he has pulled some components he felt were thermally compromised as well as the Zener which had numbers printed on it "15PP" but couldn't read without removal. I was under the impression to get the correct breakdown voltages it's best to remove a Zener?
FYI, I thought I would build this Zener identifier I came across from someone else's hard work. Also this link has probably the best Zener identification circuit I've seen yet, I'll probably build one for myself because of the amount of time I burn on this stuff, it will really pay off in the future.
https://content.instructables.com/ORIG/FGS/ZLGC/H1JU4CIV/FGSZLGCH1JU4CIV.pdf
https://content.instructables.com/ORIG/FBE/4WF8/H1JU4CIY/FBE4WF8H1JU4CIY.zip
Zip contains a BRD and SCH file and can be opened with these links.
Attached BRD file opens with http://www.extremecircuits.net/2009/12/eagle-layout-editor-free-download.html
Attached SCH file opens with http://www.fileguru.com/apps/sch_file_viewer
Original link- https://www.instructables.com/Build-a-Zener-Diode-Identifier/
Offline kishbud
« Reply #13 on: January 24, 2022, 08:25:48 pm »
That's a great observation, unfortunately I'm not in possession of the unit to confirm that, maybe he has a photo from when he removed it, I'll ask. Thanks!
Online BrokenYugo
« Reply #14 on: January 24, 2022, 10:16:42 pm »
If the zener (assuming it is a zener) is bad I'll hazard a guess it won't breakdown the way it's supposed to (bad diodes usually short out). You'll have to reverse engineer the circuit around it and make an educated guess.
