Well, it is a switched PSU, so there should be one bridge rectifier should be on the primary side, and those diode's do look to be on the primary side, but not really between the filter and the capacitor. Anyway, some trace following may easily show if they are in a bridge configuration.
Say, slight tangent: Those yellowish X2 capacitors. They are not the infamous period appropriate RIFA's are they?
