Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Glitchy 40" monitor - intermittent LCD low/columns/data connection: how-to-fix?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Glitchy 40" monitor - intermittent LCD low/columns/data connection: how-to-fix? (Read 459 times)
Odd
Regular Contributor
Country:
on:
February 16, 2023, 08:17:05 pm »
This is a Philips BDM4037UW/27
Video:
https://drive.google.com/file/d/19rhjq7ZSA0dqiuaFaVABlxAGPS-1m_ih/view?usp=sharing
First part is before disassembly. (mostly thin lines)
I touched/pressed along the edges of the display, at some point it just worked perfectly.
The I assembled it ...and the second part (filmed in landscape mode) is the result.
What would be the recommended way of fixing it? - or should I just throw it away?
Logged
cantata.tech
Regular Contributor
Country:
Re: Glitchy 40" monitor - intermittent LCD low/columns/data connection: how-to-fix?
Reply #1 on:
February 16, 2023, 10:48:50 pm »
Clean the connectors with some electronics spray that also has conductive lube in it.
Logged
Odd
Regular Contributor
Country:
Reply #2 on:
February 19, 2023, 09:11:33 pm »
really ..connectors? that's pretty far from what I would suspect. How sure are you about this?
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
