Author Topic: Glue Removal From a Connector  (Read 2988 times)
Offline ENG.TechTopic starter
  • Country: sa
« on: July 08, 2016, 04:53:12 pm »
Guys I am trying to remove a connector which is glued to a PCB the connector is coming form a small LCD display unit. What is the best way to remove the glue before de-soldering the connector from the board.
Thank you very much
Offline TheAmmoniacal
  • Country: no
Re: Glue Removal From a Connector
« Reply #1 on: July 08, 2016, 04:59:57 pm »
Cyanocrylate, epoxy or silicone?
  • Country: sa
« Reply #2 on: July 08, 2016, 05:51:25 pm »
its silicone
  • Country: sa
« Reply #3 on: July 08, 2016, 05:55:38 pm »
 please see  the connector's photo below
https://drive.google.com/open?id=0B8nQliUZiP_0OVNmWXU3UlJPekE
  • Country: no
« Reply #4 on: July 08, 2016, 06:00:44 pm »
Looks like ABS to me, try soaking it in acetone.
If it's silicone, go buy some hexamethyldisiloxane ;)
Offline ruffy91
« Reply #5 on: July 08, 2016, 07:15:44 pm »
Looks suspicoiusly like hot melt glue to me. Try to just solder through it.
Gesendet von meinem JAZZ mit Tapatalk
Offline Ijaz
  • Country: pk
« Reply #6 on: July 25, 2016, 06:27:46 pm »
Hot melt glue. A drop of alcohol (IPA) will do the magic.
Offline iXod
« Reply #7 on: July 26, 2016, 04:30:08 am »
The little-known secret of service: hot-melt just falls off in the presence of isopropyl. Quite a surprise.
