Author Topic: Reparation Hameg HM604-2  (Read 2473 times)
Online RAPo
Re: Reparation Hameg HM604-2
« Reply #25 on: August 05, 2023, 12:02:58 pm »
Great! Do you need further assistance?
Offline skopgTopic starter
« Reply #26 on: August 07, 2023, 10:20:26 am »
Hello, here is as requested, with ChI/II and Trigger pressed.
But the Trigger lamp not on
« Reply #27 on: August 07, 2023, 01:06:20 pm »
« Reply #28 on: August 07, 2023, 01:42:37 pm »
Hello, already a big thank you for your help.
Is it normal when I press the button Ch1 the trace moves down (a Square).
If I do the same for the Ch2 the trace also moves a square BUT upwards.
Button or it is written invert/CH1 and invert/CH2.
Online RAPo
« Reply #29 on: August 07, 2023, 01:46:06 pm »
Does the trigger led turn on if the level knob is wholly turned ccw detent in AT(=automatic triggering) position?
(see pag 15 in the manual)/
« Reply #30 on: August 07, 2023, 02:18:08 pm »
No and the Level button is on AT, on page 15 I only see testing diodes, semiconductors ...
Online RAPo
« Reply #31 on: August 07, 2023, 02:55:06 pm »
Regarding  your earlier question:
Yes, that is normal.
See the attached image for the pages regarding triggering.
Please set the holdoff to minimal.
If you slowly turn the level knob from fully ccw AT position (with CHI/II depressed and signal on CHII) does the signal trigger somewhere?
The following users thanked this post: skopg
« Reply #32 on: August 07, 2023, 04:08:46 pm »
suite
« Reply #33 on: August 07, 2023, 04:10:08 pm »
Suite
« Reply #34 on: August 07, 2023, 04:14:11 pm »
Suite,
Sur le Tek
Canal1 Time/Div 0.2 ms
           Volts/Div  1
Canal2 Time/Div 0.2 ms
           Volts/Div  1
Reporté sur le Hameg
« Reply #35 on: August 07, 2023, 05:04:40 pm »
That's it, set to AT, the signal goes from left to right,
released level button turn slowly to fix the signal you can see that the trigger lamp is on.
