Author Topic: GP1250 diode equivalent  (Read 1200 times)
Offline set4dTopic starter
« on: August 14, 2020, 02:20:02 pm »
Hi, new to the forum so please be gentle  ;)
I've got an amp on my bench that's come in for repair. I've found a blown GP1250 diode but can't for the life of me find a UK supplier for a replacement. Can anyone suggest an equivalent replacement please or, better still, a UK supplier?
Many thanks,
Rich
Offline Pete66
Re: GP1250 diode equivalent
« Reply #1 on: August 14, 2020, 03:28:16 pm »
I think you will have to buy in bulk:
https://www.ebay.com/itm/ROLL-OF-4561-NEW-OLD-STOCK-DEC-DIOTEC-SOFT-GLASS-DIODES-GP1250-T-R/333382714072?hash=item4d9f2882d8:g:6JcAAOSwsbhdvITY:sc:FedExHomeDelivery!60633!US!-1
Maybe ask the seller if they can sell you a few.
What is the function of the diode in the circuit?  Is it part of a bridge? Does it really need to be 2500V Reverse voltage?
Offline Audiorepair
« Reply #2 on: August 14, 2020, 03:48:16 pm »
Looking at the Forward Voltage figures in the datasheet, this device looks like a string of diodes in series in one package.
You may be able to replace with several single diodes in series.
https://www.digchip.com/datasheets/parts/datasheet/131/GP1250-pdf.php
I'm guessing this diode is on the OPT of a valve amp?
« Last Edit: August 14, 2020, 05:13:59 pm by Audiorepair »
Offline Audiorepair
« Reply #3 on: August 15, 2020, 07:38:00 pm »
Well, we know nothing of the circuit that this diode comes from, but I have seen this diode used on valve amplifier OPT's, and can be got from Farnell.
It is 4kV.
https://uk.farnell.com/vishay/gp02-40-e3-54/rectifier-std-0-25a-4kv-do-204al/dp/2335149
« Last Edit: August 15, 2020, 09:45:05 pm by Audiorepair »
« Reply #4 on: August 17, 2020, 08:48:59 am »
Thanks for this. Yes, It's from a guitar amp.
Offline Pete66
« Reply #5 on: August 17, 2020, 09:05:40 pm »
The Vishay diode is 4kv but he forward current is half of the GP1250.
Offline Audiorepair
« Reply #6 on: August 17, 2020, 09:51:18 pm »
We still don't know what this diode is doing.
If it is catching back EMF spikes, it is reversed biassed, no forward current.
