Author Topic: GPS Locator device antenna broke off... (device takes GSM Sim card)  (Read 1881 times)
Offline salilTopic starter
This is one of those GPS things you can stick in a car and it will send you text messages back with the GPS coordinates using a prepaid GSM sim card, similar to this but it can also do audio:
http://www.ebay.com/itm/Mini-Global-RGPS-Tracker-GSM-GPRS-GPS-Tracking-Tool-For-Children-Pet-Car-hg-/281513973063?pt=LH_DefaultDomain_0&hash=item418b8a5547
Unfortunately, I lost the hard-to-find charging cable for a while, (since found) so when I decided to open up the unit, the antenna broke off the board at it's single weak connection point. (see upper left corner of picture below)
 Is there any way of reattaching this?  My first thought was that the pad for the antenna had lifted.  Upon scraping off some of the board in the area where the antenna was attached, I found copper and a continuity check told me it was tied to ground.
One of my EE friends suggested that they may have used a very small amount of insulation between the antenna solder point and the ground layer of the board to act as a tiny, tiny capacitor?  Any idea if this is repairable?  What are your thoughts?  Thanks for reading.
« Last Edit: April 25, 2015, 05:32:25 am by salil »
Offline richard.cs
  • Electronics engineer from Southampton, UK.
    • Random stuff I've built (mostly non-electronic and fairly dated).
Re: GPS Locator device antenna broke off... (device takes GSM Sim card)
« Reply #1 on: April 26, 2015, 09:35:37 pm »
Looks to me like it's designed so that the same board can be used with an external antenna by snapping that bit off and using that connector nearby. You may find there's a link you need to fit to use the connector or it may connect when you fit the mating half.
Offline Rasz
    • My random blog.
« Reply #2 on: April 27, 2015, 07:40:49 am »
no its not, it uses GSM tower location, no gps there
