I think the max temp is more a matter of frequency stability than survival, I mean they're made of quartz, there's a reason they use that stuff to make arc tubes in discharge lamps.
Anyway first step here is determine whether it's a plain crystal or (more likely I think) a complete oscillator. Then if it's the latter, check the supply voltage, this would be on pins 2 and 4, so lower right, top left.
