Author Topic: Teardown, Repair & Experiments of an Agilent E7495B 2.7GHz Base Statio Tester  (Read 2534 times)
Offline Hugoneus
    • The Signal Path Video Blog
You can watch the video here: [23 Minutes]
youtu.be/IWW2_VzIEXg
More videos at The Signal Path:
http://www.TheSignalPath.com
Online PA0PBZ
Well, that was ugly. Looks like they took the necessary parts from the N1996a and somehow managed to put in in that housing  :palm:
Anyway, if you want to enable some more options have a look here: https://www.eevblog.com/forum/testgear/agilent-e7495-linux-root-account/msg615695/#msg615695  8)
Offline Towger
  • Country: ie
Ribbons galore.
I wonder what Bill and Dave would have said if they saw the inside of that unit being developed.
Offline TheSteve
  • Living the Dream
Pretty weird indeed, especially considering his big brother the N1996A is so neat and tidy. I think they would be much more valuable if the source frequency didn't start at 375 MHz.
Shahriar - please help with my PM if possible, you're my only hope!
VE7FM
Offline AF6LJ
Wow..
Talk about five pounds of compost in a four pound bag...
That is almost as bad as my IFR FM/AM 1000S
Sue AF6LJ
Test Equipment Addict, And Proud Of It.
Offline Hugoneus
Thank you!
Offline AF6LJ
Good video thanks.  :-+ :-+
Sue AF6LJ
Offline mmagin
Thanks for the video, I have one of these or a very similar model -- It also seems to be a dead power supply.
Looks like it may have some display damage, but until I light up the display, I'm not sure.
Sadly it has some other physical damage to the RF in/out I may have to improvise a fix for out of semi-rigid coax and decent connectors.  (Or see if Keysight is only asking reasonable prices for the part.)
Offline TheSteve
  • Living the Dream
I've seen mention that some people have had the LCD screen start to de-laminate. Post up some pictures and maybe we can offer some advice on how to handle the damaged RF in/out connector.
VE7FM
