Hi .
I am new as a member on this forum. So ,first of all, let me greet everybody.
I hope not to be posting on the wrong section: I apologize if this is the case .
From today I am the owner of an old Tektronix 465. I immediately started to examine it. It is really beautiful .The instrument seems to work correctly.
Apart from one stiff potentiometer , I found that the trace goes out of sight pressing the CH2 INV button (I need to use the vertical position knob to make it visible again). After some head scratching ,I searched on the schematics, and I concluded that one of the to transistors Q228 or Q226 on the channel 2 vertical preamplifier is bad. I found that these two NPN transistors should be matched , but I have no idea of what type they are.
Is there somebody who can help me telling 1) if my initial hypothesis is correct , 2) if yes what are the transistors suitable to do a repair
Any idea or information is wellcome
Thank you very much
