Author Topic: Grundig MO22 / Siemens D1011 service manual needed  (Read 2777 times)
Offline philTopic starter
« on: November 21, 2014, 11:14:51 am »
Hello,
I recently got a Grundig MO22 20MHz scope by luck - absolute beauty! However, it is way out of spec and needs some recalibration.
The problem is: I could not find any service (or even user) manual for this scope. I know that it was sold under the name "Siemens Oszillarzet D1011", too.
Does anyone here have a service manual or other documents for this scope?
Thanks in advance,
phil
Re: Grundig MO22 / Siemens D1011 service manual needed
« Reply #1 on: November 23, 2014, 02:42:12 am »
Never mind.
I took it apart to see whats inside - and was very suprised. It was my first time taking a Grundig apart, so I did not know what to expect. This scope is especially designed to be repairable. The front plate is split into modules that plug into a frame. That means that you can take out a board without having to unscrew any knobs. The corresponding front plate segment just comes off, too.
Also, there is some excessive silk screening that is nearly as good as a service manual with explaining whats going on. All pots have a description printed besides them. Recalibrating the unit was easy with that.
This is a late 80ies unit afaik. Even though it has only 20MHz BW they added a delayed time base and replaced the horizontal selector switch with a digital solution. And that solution comes with a horizontal auto set function :D
Such a bummer that I cant find any documentation besides a schematic.
