Hi, I am trying to fix this Color monitor.
1) It works well, with a crisp and colorful image… sometimes.
2) Most of the time it behaves with a failure mode where it displays only b/w, with some flickering near the bottom section of the screen.
3) Under this failure mode, when fed with B/W, the image looks as expected (shown in the first picture with grayscale gradient bands)
4) But when color images are fed, it shows them in B/W. The second photo shows the display when horizontal rainbow colors are fed through composite input (vertical B/W thin lines are displayed instead).
Sometimes it comes back to normal, without user action involved. I don't believe it's temperature related because It may randomly go back to normal without touching anything.
I believe these monitors can automatically detect NTSC/PAL/SECAM. I suspect it is switching to PAL for some reason but I am not sure.
Any ideas of what could be failing?
