Author Topic: GW GPC-3030 power supply  (Read 1044 times)
Offline LA2BPATopic starter
  • Country: no
« on: November 02, 2024, 10:17:45 pm »
I have a GW GPC-3030 power supply. It has three channels, two of them is adjustable (master/slave).
The master channel seems to be working as it should, however the slave channel is not.
The output voltage can't be adjusted, it just stays at 32V whatever i do.
I have checked op-amps, transistors, diodes and potmeters in the regulator circuits.
Any ideas?
« Last Edit: November 12, 2024, 09:23:08 pm by LA2BPA »
Offline Harry_22
Re: GW GPC-3030 power supply
« Reply #1 on: November 03, 2024, 10:33:56 pm »
Hi!
Could you attach a photo of PCB. I think I have a similar device.
  • Country: no
« Reply #2 on: November 10, 2024, 10:08:30 pm »
Here is a couple of images of the unit. Frontpanel, main pcb and a bird view.
2431685-02431689-12431693-2
Online wraper
  • Country: lv
« Reply #3 on: November 10, 2024, 10:12:31 pm »
Measure voltages in operation. Start from measuring if potentiometer actually adjusts the voltage on its wiper terminal.
Offline Poroit
« Reply #4 on: November 11, 2024, 06:16:20 am »
This may help if you don't already have a copy.
Page 5 gives you a Circuit Arrangement.
The following users thanked this post: Harry_22
Offline Smokey
  • Not An Expert
« Reply #5 on: November 11, 2024, 06:39:54 am »
I have two of these.  One had a problem on the slave channel that I quickly tracked down to a failed power diode across the output.  Grabbed something from the junk bin and was back in action.  Had to erase the "NFG" from the front panel once I got it working again.
Online wraper
  • Country: lv
« Reply #6 on: November 11, 2024, 12:19:26 pm »
BTW, as it has single layer boards, it's not necessarily a bad component. As these boards have on hole metallization, solder joints are prone to cracking.
Offline Harry_22
« Reply #7 on: November 11, 2024, 01:44:33 pm »
Please enlighten me, is it a common tradition to write like "No Freaking Good" on faulty devices?
I have mostly the same PS.
If we can't find a schematic diagram for it, this will help.
Offline Grandchuck
« Reply #8 on: November 11, 2024, 03:44:01 pm »
I have a HY3005F-3 which might be similar.  I have attached a schematic.
Offline Harry_22
« Reply #9 on: November 11, 2024, 04:04:33 pm »
Yes, many thanks! Seems mostly the same.
Offline Smokey
  • Not An Expert
« Reply #10 on: November 12, 2024, 07:59:38 pm »
...close enough :)  That was pretty much the universal warning markings that something was broken by the grey beards I learned from.  I still have a few partially working pieces of equipment in line for repair with "NFG" above some function or another.  (That's right!  I'm talking to you Keithley 196 resistance mode!)
  • Country: no
« Reply #11 on: November 12, 2024, 09:19:54 pm »
I've found the problem :-+. A cracked pcb track on the front panel board.
2434201-0
The following users thanked this post: Ugur
Offline Harry_22
« Reply #12 on: November 13, 2024, 07:56:45 am »
Yes, grey beards will not give bad advice.
PS
Now in every service :)
