Author Topic: GW Instek GDS-2072A - no boot  (Read 540 times)
Offline just_hobbyTopic starter
« on: November 05, 2022, 11:42:17 pm »
I have GW Instek GDS-2072A for about 3 years.
Today I had a chance to use it, but it didn't boot for me :(
I haven't used it for about 6 month due to moving to another house.
Where do I start with fixing it?
Thanks
1632382-0
Re: GW Instek GDS-2072A - no boot
« Reply #1 on: November 06, 2022, 06:14:04 pm »
All right, to bring it to life I had to update firmware in safe mode.
Power up the oscilloscope and at the same time, keep rotating the “VARIABLE” knob a number of times until the oscilloscope boots into the firmware upgrade safe mode.
Then I performed SPC Calibration and vertical Accuracy Calibration from the Utility section.
The following users thanked this post: shakalnokturn
Offline shakalnokturn
« Reply #2 on: November 06, 2022, 10:30:03 pm »
It's funny how the GoodWill Instek scopes tend to get corrupt firmwares so easily.
I once had an older model that had a bad firmware and if you look around it's almost common.
