Author Topic: GW-Instek GDS-800 Service Manual  (Read 2243 times)
Offline msrayaTopic starter
  • EA7EE
« on: June 08, 2017, 09:28:57 am »
Hello!
I have a problem with an Promax OD-581 with vertical chanel accuracy...
This Oscilloscope is a clone of GW-Instek GDS-800 series...
I Only need service manual in order to run the auto cal function that the instrument have.
It uses a BNC in the rear panel to do the AUTOCAL.
But Promax in Spain only do calibrate the instruments if I send It to them..  :-//
So if someone have the Service Manual PDF and send it to me, I will thank You forever  :)
Regards
Manuel
Offline Machlee
  • Country: ru
Re: GW-Instek GDS-800 Service Manual
« Reply #1 on: October 17, 2024, 06:44:22 am »
Hello!
I need the same thing. :scared:
Offline tatel
« Reply #2 on: October 19, 2024, 11:08:09 am »
You could perhaps contact Promax, they were nice enough to send documentation about a power supply to me.
https://www.eevblog.com/forum/testgear/(rebadged)-promax-fac-364b-power-supply/msg5561753/#msg5561753
