Yes but guessing will not advance the diagnostics as there are many causes of boot failure
For info, a service manual for embedded computers can be pretty simplistic as it just shows various 'blocks' connected together by data, address and signal paths. They rarely contain any OS detail. You might get lucky and find a diagnostics mode detailed but that needs the unit to boot first !
Many modern service manuals for such equipment just contain basic tests like those already detailed, and then board replacement recommendations plus calibration procedures. If you want to get to the bottom of the problem you will need to do a lot of physical diagnostics to establish what is, and is not happening. All Reset lines, HALT pins and any error indicator pins need to be checked for state. A simple RAM failure can cause failure to boot. Corrupted firmware is an ugly possibility, rendering the unit bricked and non responsive.
I worked on a thermal camera with similar symptoms and even reverse engineered the embedded computer to see what was where. After a lot of tests I proved that the board was working but was seeing a critical failure on another board. The fault was a simple Reset line buffer on the video processing board. A 50 pence 74ALS244 chip ! It took time and a lot of effort to reverse engineer the design so it is sometimes best to bite the bullet and go for OEM repair if simple tests reveal nothing obvious, like a clock generator or Power On reset management chip failure.
Aurora
