hope someone can help me identify the fault with my GPS-3030D supply. It's particularly a particularly evil problem which occasionally seems to disable any regulation from the supply. In other words, I connect it to some device which needs power, leave it to do its thing then sometime later come back to a smoking ruin.
Basically the symptom is that at some random time after turning on the supply, the output will shoot up to 40+ volts and the current will display 4+ amps (it doesn't necessarily output this current as it still shows this even with no load). Turning it off and on again doesn't necessarily reset this condition - it seems to recover just as mysteriously as it appears.
During the latest episode I was able to turn the supply on and off a number of time and move it between desks and even from home to my office workbench without clearing the fault, only for it to recover after a few minutes when I had it left it open and powered up on the bench.
I tried wiggling various connectors to see if it could provoke the issue again but no luck, plus as far as I can tell, the fault doesn't seem to be related to mechanical vibration.
So... anyone experienced this issue before? (And hopefully solved it)
