I'd like a little advice here from anyone who has a little experience on arc welder repair.
This welder GYS Inverter 3200 has a few clones with different names. PCB model is 64184IND7-P, that being the best way to find any schematics for GYS equipment.
The welder has a rated no load output of 80V and a maximum current of 130A@25.2V
I bought this broken looking for something different to repair and then learn to use. The previous owner said that it got hot (thermal protection LED on) but no longer worked once cooled.
When I received it the SMPS was in hiccup mode, this was narrowed down to 1 of the 3 STTH2003CG double diodes on the heatsinked IMS. (Total of 6 parallel diode junctions for freewheeling along with 2 parallel R-C series snubbers.)
One diode of the 2 in the middle STTH2003CG was shorted, the surviving one had an abnormal curve.
I ordered a replacement from Littlediode on eBay then got hot and bothered replacing it on the IMS and once replaced and reassembled took it for a quick test. Quick because it failed after 5min...
The diode I had replaced has failed again, I do believe the layout is not perfect and that the centre one gets hit by more current than the others but this time it got hit so hard that it partly desoldered itself from the IMS !
Seeing this I have the feeling that I was maybe sent a fake diode, I don't really trust any eBay semiconductor sellers.
What else should I be checking before attempting to replace this diode once more?
Schematic can be found here:
http://valvol.qrz.ru/schems/Gysmi-131.pdfGYS is a French brand and the French really are NO good at schematics... sorry for the headache.
The only difference is my PCB does not have the small section with Q33P01, Q33P02... of that part it only has D33P06.
Also what are good practices for rework on IMS?
