The uPC1701 appears to be off, no output at pin 6 to turn on the triac. But control input pin 4 is more negative than pin 3, which I believe requests heat. Higher+ voltage on pin 4 turns off the triac, I think there's an inverter in the IC. So the 1701 might not be doing anything? It's difficult because the IC datasheet is in Japanese. Thanks for all the voltage readings.
Pin 4 of the 1701 is connected to -9V via R16 (75k).
The voltage drop across R16 is around 3V.
If I'll increase the value of R16 to 150K the voltage drop should be around 6V so pin 4 will become more positive than pin 3.
Do you think it's worth to try this experiment?
Also when I connected the scope to pin 6 this is what I saw:
It seems like there's some pulse coming from pin 6.
This is what I want to see at pin 6?
A few other signals look wrong too.
The signal at U9 uPC324 pin 8 oscillator should be a nice 2.5Hz narrow pulse. No sine wave.
The signal at U9 uPC324 pin 1 should be a small sine wave, the setpoint pot is driven by 24VAC not DC.
The signal at U9 uPC324 pin 7 should be a square wave. Pin 5 should be up a bit at 0.163V not 0V.
At pin 1 there's a sine wave, at pin 7 there's a square wave, at pin 8 there's a 50 Hz half sine half triangle wave.
I made this short video of the waves as seen at my scope:
https://youtu.be/0O_O5lcVkOUI took another measurement at pin 5 and indeed there's 159 mV over there.
Does those measurements pointing on the faulty IC?
I can order new 324 and new 1701 ICs and test the circuit again.
